Ball Joint question
Old Jul 31, 2010 | 01:46 PM
starrider's Avatar
starrider
Ball Joint question
1997 E-150 van
I have to replace the passengers side ball joints. This is the 2nd or 3rd set in about four years. What would cause this? After I replace them what else should I check?
Old Jul 31, 2010 | 11:41 PM
jeffnick's Avatar
jeffnick
My E350 BJ's were replaced because of a noise up front. The new BJ's didn't fix the problem but they did have a place to put a zirk fitting to grease them. You might see if you can grease yours?
The nopise was because the body to frame bolts needed snugging...a fix I eventrually did myself after tips from this board.
Old Aug 1, 2010 | 06:30 PM
JWA's Avatar
JWA
Typically factory installed ball joints do not have Zerk fittings----not their problem I'm sure is the prevailing attitude!
Replacement parts do which makes keeping them greased without over filling and "blowing out" the boots easy and essential.
The body>frame bolt check would be a good place to look as well---I should do that with my 2000 E250 in fact!
briangelc
Jan 4, 2020 08:37 AM
bigcountry1009
Jun 19, 2014 03:28 PM
Curt's05
Jul 15, 2013 06:55 AM
Lstanley
15
Feb 15, 2011 06:22 AM
Capt.Schenk
Dec 21, 2008 06:45 AM
