1970 Bronco suddenly stalls, HELP
Old Jul 31, 2010 | 01:46 AM
vreeland274's Avatar
vreeland274
I FEEL LIKE IM TAKING CRAZY PILLS, could somone please help, I have a 1970 Bronco, with a 302, it will suddenly stall??? New Fuel pump ( Electric ), new coil, points condensor, plugs, wires, cap and rotor. It does this intermittently. When it stalls, I can most of the time restart it, it is like it loses spark.......
Old Jul 31, 2010 | 10:18 AM
JRM1972's Avatar
JRM1972
Bad distributor? that is the only thing I can think of based on what you have replaced etc.
Old Aug 2, 2010 | 12:29 AM
GreenDinosaur's Avatar
GreenDinosaur
Is your ignition switch good? is your engine running warm? I had the same problem on my 73 dodge and found that it was boiling the fuel clean out of the carb. the ethenol blend gas has a lower boiling point. Even my 70 f100 when the engine temp gets up past 180 will start to vapor lock.
