Going to install a mustang gas tank in back.Don't like bed mounted gas doors so I want to put in a door in the side of the bed.Who has done it and what is the best door to get?
The problem that I have seen with rear mounted gas tanks is the filler tube being too level, making it difficult to fill.
Ever see the guy at the gas station that has to drive up on a block of wood just to fill'er up?
I think it's more common with a tank thats mounted between the frame rails.
As far as the door it self, just see what you can find. I'd look for a more square door myself. I've even seen them up under the fender.
use the dent side bed door. but you will have to move the filler tub in the tank to do this. take a look at using a 70's chev suburban rear tank. i have herd that they fit.
