Fuel Circuitry problem - 1990 F150
Old Feb 12, 2003 | 11:10 PM
laka's Avatar
laka
Angry Fuel Circuitry problem - 1990 F150
Ok, here it goes.
The rear pump on my truck is almost dead (barely keeps the truck idling) so I rely on the front one. Well the front one died today, I removed it and hot-wired it and it does work.
Checked for power at the connection for the front pump, not enough for test light, but multi-meter picks up some power. And when I test the switch inside the cab, the test light picks up nothing, but multi-meter does. I messed around in there once, and thought there was enough juice (12v?) to run a test light?
Pulled off relay and tried hot-wiring the wires - with switch on back tank, i can get the pump to work. With switch on front tank, the pump doesn't work, but I hear the plug "clicking".
It seems that If i switch the back tank's plug to the front tank, then front tank would work. I checked the wiring, nothing looks broken at all.
I'm going to get a new relay tomorrow morning. I could only find 2 relays under the hood above the fender, one for fuel, one for ??
Sorry if i'm not making much sense, it's been a long day. Maybe if anyone's gone through something like this they could give me a shout.
Jason
1990 F150 4x4 302 5spd
Old Feb 13, 2003 | 06:53 AM
shotgun's Avatar
shotgun
I read a few years ago about a guy with a truck just about your vintage with the same trouble and symptoms. Long story short. They ended up taking a test light with the sharp point. Located the hot lead going from the fuse/relay box under the hood down to the frame and on back to the tanks.
As they probed the wire with the test light they found about two feet down the hot lead that: Although it looked great on the outside, inside the insulation the wire had corroded and turned to powder. Causing the intermitten problem. The wire was MUCH cheaper than a fuel pump and easier to replace. Good Luck. Hope this helps.
Chris
Old Feb 13, 2003 | 07:32 AM
steve83's Avatar
steve83
The other relay is the EEC PWR relay, and it sends power to ALL the sensors & injectors AND to the FP relay. Try running a power wire directly to each pump (and a ground off each one, of course) and see if they run. If they do, it's definitely a wiring problem. Bypass each component with a hot wire to find out which one is open.
Joel Cassell
23
Aug 1, 2015 02:33 PM
RDM83
Apr 25, 2014 08:59 AM
biztyke
Jun 12, 2013 01:27 AM
jason kitch
Apr 13, 2012 03:04 PM
