Modular V10 (6.8l)
SCT X3 from Five Star
Old Jul 30, 2010 | 01:54 PM
Mud-and-Guts's Avatar
Mud-and-Guts
I am just curios how many times everyone has flashed their trucks from one tune to another..
Old Jul 30, 2010 | 05:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I've done it about 15 times so far. Why do you ask?
Old Jul 30, 2010 | 05:45 PM
Mud-and-Guts
Just curious... I have done it a few times... I ran the 87 performance first and after a few miles decided to try the 93 performance with a little 87 left I filled with 93 and had a lot of rattle so I went back to the 87 and now after several tanks of 93 I decided to try the 93 tune again to see what it does with the mileage...
Old Jul 30, 2010 | 05:51 PM
krewat's Avatar
krewat
Interesting. Your knock sensor should take care of that unless it needs more than 4 degrees timing pulled out.
When do you get the rattle, at partial throttle or WOT? If it's WOT, you can add more fuel or pull timing out.
If it does it again, contact Mike, I'm sure he'll take care of you.
Old Jul 30, 2010 | 07:51 PM
Mud-and-Guts
I assume it was the mixture of gas that was causing it.. It was rattling pretty bad on accel and when under load..
When pulling my 16ft utility I also noticed with the 87 tune and 87 octane it had a little knock when under load so I started running 93 with the 87 tune and had no issues with good mileage.. Just lately decided to try the 93 tune with 93 octane to see if it affects anything... I flashed it this morning but haven't drove it yet...
Old Jul 30, 2010 | 07:53 PM
wallz's Avatar
wallz
Had mine now maybe three weeks, and have flashed about ten times.
Old Jul 31, 2010 | 10:35 AM
rob17's Avatar
rob17
Twice for me. I initially tried the 87 towing w/o overdrive. I didn't care for the performance so I went to the 87 towing with overdrive and I'm much happier with the truck performance.
Rob
grizcty
New Member Introductions
Nov 17, 2013 11:45 AM
nordictom
Nov 13, 2013 09:10 AM
Cbreeze3
Aug 26, 2013 01:08 PM
barecove
New Hampshire Chapter
Jul 1, 2008 04:34 AM
weldman
Nov 5, 2001 12:01 AM
