AC clutch replacement
Old Jul 30, 2010 | 01:27 PM
straightsixer's Avatar
straightsixer
F150 351ci 1994, how does one remove and replace the ac clutch?
Old Jul 30, 2010 | 02:38 PM
Encho's Avatar
Encho
The Southernmost Mod
You need to look the movement on the center plate while you turn the nut in the center until it's loose, take it out and and remove the plate, then remove the first C-clip, then the rest of the clutch, then the other C-clip and the coil (if for some reason the wire that powered the AC compressor snapped) <--- this was the procedure on a Sanden 508 (non-stock) unit.
Old Jul 30, 2010 | 02:42 PM
straightsixer
And this can all be done while the compressor is still in the car?
Old Jul 11, 2012 | 10:58 PM
Encho's Avatar
Encho
I'm sorry for the very late answer, but to complete the info for anyone else: It can be done with the compressor installed.
Seth2w
13
Jul 26, 2015 08:18 PM
TBoxx
Jun 12, 2015 05:08 PM
RavenR90
1983 - 2012 Ranger & B-Series
Jul 10, 2014 10:32 PM
epdukes13
May 25, 2014 08:47 PM
macedonia64
Jun 23, 2013 04:13 PM
