Does anyone have an extra front driveshaft or know where I can get one reasonably for a 74 F250 w/D44. When we bought the truck back seems the PO put a nice kink in it. Anyway I'm located in York, PA if that helps.
Thanks
yea the tube is the only thing bad, I should call around see what the shops will charge. We need to have the driveshaft fixed and the truck lifted a little by Oct. and time is running out. I should start another thread here it will be interesting and quite funny actually, we are going to have a little exhibition pull against my uncles 2wd pullin truck in Oct.
Should be interesting. There will be no clay track just a grassy field and we should have a higher hitch height once lifted. The weight between the two will be equal. So we'll chain them together and see what happens.
