holy crap
Old Jul 29, 2010 | 10:26 PM
johnboggs21's Avatar
johnboggs21
holy crap
Just took the ole truck for a drive........I never realized how much power the ole bugger had lol. Guess all it took for me to notice was driving the V6 for a couple weeks lol........good inspiration
Old Jul 29, 2010 | 10:34 PM
Blueovals&Blacksmoke's Avatar
yeah i drove my buddies 4.3L V-6 half ton chev when i was down in dillon and it was amazing how much of a difference there is
Old Jul 30, 2010 | 08:32 AM
johnboggs21
yea that stupid 4.2 takes forever to get up to speed lol. Gotta rev the crap out of it to see any power, and you can forget about spinning the tires on pavement lol. Dumb thing is only getting 16mpg too, the ole heavy diesel got 21!
Old Jul 30, 2010 | 10:27 AM
joe f350's Avatar
joe f350
told u to keep the idi
Old Jul 30, 2010 | 11:25 AM
David85's Avatar
David85
OMG that F150 is a V6? What were you thinking! LOL
But John, don't you know anything? the specs clearly state that the V6 has more hauwss powaa! LMAO
Ford Essex V6 engine (Canadian) - Wikipedia, the free encyclopedia
Old Jul 30, 2010 | 07:13 PM
yeah but its also missing about 250 ft lbs of torque lol
Old Jul 30, 2010 | 08:06 PM
LCAM-01XA's Avatar
LCAM-01XA
I could say the same about my buddy's 4.3 Blazer and my own IDI - difference is the Blazer just hauls when you get on it while my 1-ton is about as fast as a herd of stampeding turtles
Old Jul 30, 2010 | 08:12 PM
no the difference is that with a couch and a 2wd 250CC ATV in the back of the 4.3 it got 14 mpg... whis is what mine would have got with a cord of wet larch in the back... oh and 4th gear pulls up 4% grades are fun.... NOT
Old Jul 31, 2010 | 01:07 AM
David85's Avatar
David85
Torque? whats that?
In my opinion most of the V6 experiments of the 80s and 90s were essentially failures. The idea I suppose was fewer cylinders resulting in more less fuel consumption than a V8 but more power than a four popper (and a little smoother).
The only V6 powered light vehicle I ever saw that delivered reasonable MPGs was my sister's 2.9L EFI before it was converted to diesel but that was a non EGR engine from factory so that helped (ran well without the cat too!). On a good day it would stay consistently above 20 MPG on the highway. For a compact 4x4 that was pretty decent considering it still had enough grunt to squeal the tires. Although Mine will deliver similar MPGs while moving nearly twice as much iron. Never had a chance to test a 55 MPH run with the ranger as a diesel though.........I do remember it came close to 30 while pushing 80 MPH once on one of the few long haul trips we ever took it on.
Anyone remember the V6 powered F100 from the early 80s?
Old Jul 31, 2010 | 10:01 AM
WarOzz's Avatar
WarOzz
I towed my 3500 lb boat once with my old 94 Ranger with the big 4.0 V6. It towed it ok but the damn thing could barely get the boat out of the water. I had to put her in 4 low 3rd gear and even then I could smell the clutch burning as I was climbing the boat ramp. V6's just are not made to work like our diesels.
Old Jul 31, 2010 | 10:06 AM
johnboggs21
Initial output of the 4.2 L V6 in the F-150 was 202 horsepower (151 kW) at 4800 rpm and torque of 252 lb·ft (342 N·m) at 3400 rpm.
look how high ya gotta rev the damn thing to get anywhere. I aint used to revving that high lol.
Old Jul 31, 2010 | 11:05 AM
David85's Avatar
David85
Never tried that with our ranger but low range and 1st gear would likely break traction before stalling or burning the clutch. Closest thing we ever did was to load it with 2000lbs of cement bags and while it did feel the weight, it was still pulling it. The last couple of stop signs were pointing uphill and I had it in low range making use of every gear. Felt a little soft and "floaty" but it pulled away as hard as I was comfortable pushing it. Felt like driving a mini-rig. Although it was already a diesel by then.
Yeah it takes some getting used to when you go back to a gasser. My F150 is a pig anywhere below 2500 RPM and only starts really hauling above 4000. I only discovered the higher RPM a few years ago when I was rebuilding the 6.9. Was an eye opener to hear the ol 302 roar like that but it was able to move. The AOD combined with 3.55 gears also result in a slow pull off the line with pretty wide gear spread. 2nd-3rd often falls flat on its face if you aren't careful. Just tap the pedal with the taller geared turbo 6.9 and you are pushed in the seat right off idle
Old Jul 31, 2010 | 01:07 PM
WarOzz's Avatar
WarOzz
With the BFG All Terrains it had on it breaking traction didn't happen. On more of a street tire I am sure I would have been burning rubber all the way up the boat ramp!
Old Aug 1, 2010 | 10:47 PM
tabascom16's Avatar
tabascom16
Yeah. I always feel that my truck is sooo slow until i get in my dad's 97 F150. Gotta really get the gassers revved up to do any good. Diesel have very usable horsepower. If I would get rid of the 38.5" mudders and get the donut tires my truck would probably feel like even more of a beast.
dannyboy950
Sep 17, 2014 05:26 PM
seajr1978
Mar 23, 2013 10:01 PM
ramarado
Mar 8, 2008 09:45 PM
busted knuckle
Sep 20, 2005 06:13 PM
1ole4d
18
Nov 8, 2002 12:19 PM
