intermitten starting problem - Broken starter ring gear teeth?
Old Jul 29, 2010 | 02:28 PM
seventyseven250's Avatar
seventyseven250
On my 2000 Expy, I've having a very occasional starting issue. Probably only happens once in twenty times.
When I turn the key, it makes a very loud noise, which I'm pretty sure is the starter turning and just failing to engage the ring gear properly. Can't really describe the noise.
Often it will do this once or twice and then start normally. Sometimes it take more tries.
Doesn't appear to be any correlation to temperature, or how long its' been sitting.
I'm 90% certain it's the starter pinion gear failing to engage the ring gear, probably due to a small number of broken teeth on the ring gear. Only happens once in a while due to the fact that most of the teeth are still fine.
So, questions:
1) does my diagnosis sound reasonable?
2) how hard is it to replace the starter ring gear?
tia.
Old Jul 29, 2010 | 11:45 PM
bnovak's Avatar
bnovak
I'm going to guess it's not the ring gear, but the starter pinion-spring is worn out, or gummed up internally. Generally speaking, when this kind of thing happens, basically the starter spins but the pinion doesn't ride up the shaft and engage the starter ring, causing a screeching noise. The pinion and ring are chamfer-cut and made of hardened steel, so throwing a tooth is a damn good trick.
If you have pulled the starter, make sure the pinion slides EASILY up and down on the pinion shaft. If you can, hook it to another battery OUTSIDE of the vehicle, and see if it works properly.
If you are in the northeast, or anywhere there is salt, this pinion jamming can be common. We actually see it on jetski's all the time becuase of the marine environment as well.
Old Jul 30, 2010 | 12:01 PM
seventyseven250
Salt is common up here in Alberta, so that might just be the trouble. I'll see about pulling the starter and check that out.
Old Jul 30, 2010 | 12:20 PM
alloro's Avatar
alloro
Is it a squealing noise or a grinding noise?
Old Jul 30, 2010 | 01:53 PM
kailor's Avatar
kailor
About every 100 starts, or so, my 2000 will sound like I'm trying to start the car while it is already running.
Old Jul 30, 2010 | 04:49 PM
seventyseven250
Definitely not a squeal. Pretty much like Kailor described it, sounds like the noise that happens when you try to start a vehicle that's already running.
Guess you could call it a grinding, but it's very high frequency. Over the years, I've heard just about every kind of noise that an engine can make while not starting, and this is pretty unique.
Old Jul 30, 2010 | 05:15 PM
bnovak's Avatar
bnovak
yeah, that's the sound of the starter pinion not fully engaging. 99% of the time, the starter either needs to be replaced, or at least the pinion needs to be rebuilt. Trust me, helluva lot easier than replacing the flywheel.
There's a spring mechanism on the inside of the pinion that corrodes and causes this issue. My money is that is the issue.
Old Jul 31, 2010 | 05:31 PM
Moto Mel's Avatar
Moto Mel
When you get the starter out you should also turn the engine over by hand and inspect the ring gear teeth. Use a file and remove any burrs you might find.
Old Jan 23, 2013 | 02:49 AM
Singlemom3's Avatar
Singlemom3
I am currently experiencing the same problem. The difference is I had it repaired about 2 months ago and it's happening again. This time it is relatively worst. The mechanic who did the previous repair stated at that time if it happened again then it's the flywheel.
Does anyone know the symptoms for a bad flywheel?
BTFordGuy302
Jun 24, 2017 07:16 AM
crossy
Jan 22, 2017 04:14 PM
zdumpor
1978 - 1996 Big Bronco
Jul 10, 2016 03:49 PM
jvmcc
Jul 10, 2016 09:50 AM
BuckHammer
55
Jan 31, 2011 12:59 AM
