Sponsored by: Real Truck
Where Does The Heat Shield Go?
Old Jul 29, 2010 | 11:49 AM
Hobie16's Avatar
Hobie16
I have a '05, F250, V10, CC, short bed; while working on a tire rotations I noticed a sheet of heat shield material laying on top of the exhaust pipe above the rear axle. I can't figure out where it came from. The size is about 12"x18", foil with a fiberglass mat backing. The sheet is exactly the right length to span the bed support brackets space but I could not find any indication of how it was fastened or where. Since the exhaust pipe bends up over the axle tube at this point, I think it is ment to shield the underside of the bed.
Can anyone take a look at their truck and see if they have the same configuration and tell me how it attached.
thanks
Old Jul 29, 2010 | 11:50 AM
dkf's Avatar
dkf
It was probably glued into place. I had a similar shield on my 04' and it was glued on. I pulled it off.
Old Jul 29, 2010 | 11:52 AM
jc8825's Avatar
jc8825
It does attach to the underside of the bed where the pipe clears the axle. How it attaches I don't know. Probably an adhesive. Get a can of 3M Super 77 spray adhesive and stick it back on.
Old Jul 29, 2010 | 07:30 PM
Hobie16's Avatar
Hobie16
A little Dab did it!!
Thanks guys; I love the FTE, always get a good answer.
I stuck it back over the pipe with a few dabs of RTV and duck tape to hold until set.
Thanks again
Shernius
1997 - 2003 F150
Jul 31, 2014 09:31 PM
77-250
Dec 29, 2010 09:57 PM
Fard
Sep 4, 2007 05:20 PM
gregg_a_g
Feb 26, 2007 05:45 PM
rosa70
Feb 26, 2005 12:33 PM
