power loss problems
Old Jul 29, 2010 | 09:46 AM
idigplanes's Avatar
idigplanes
power loss problems
I have a 1993 F150 w a 5.8L. this truck seems to run well. High mileage but no missing or hestation, uses no oil. Where is the power? I try pulling my medium size ski boat and can barely get it moving. Borrowed a friends 6 cyl truck and pulls fine with that. What may be causing this?
Old Jul 29, 2010 | 09:50 AM
idigplanes's Avatar
idigplanes
Also I think my gas mileage should be a little better than 13 MPG no matter how I drive it. Is that what I should expect?
Old Jul 29, 2010 | 11:08 AM
f-150_1993's Avatar
f-150_1993
sounds like it needs regular maintenance (tune-up). also check if your timing is set at 10 degrees BTDC. Ask me why I know this.
Old Jul 29, 2010 | 11:11 AM
f-150_1993's Avatar
f-150_1993
what are your driving habbits? i think that should be just right. i don't know if '93 5.8's came with MAF. When they started using it, it really improved fuel economy.
Old Jul 29, 2010 | 12:03 PM
Encho's Avatar
Encho
The Southernmost Mod
If you drive too hard, don't expect anything much better than 8 MPG.
Old Jul 29, 2010 | 12:32 PM
idigplanes's Avatar
idigplanes
I have replaced plugs, wires, rotor, dist cap. Timing seems to be on the pointer when i checked it. I drive pretty easy so I guess 13MPG is ok. What is MAF
