Rattling noise that i CANNOT trace!
Old Jul 28, 2010 | 08:05 PM
powerstroke1869's Avatar
powerstroke1869
Ive been dealing with this rattling noise coming from my drivers side front everytime i hit a bump for the past year. I have replaced my shocks, did the sway bar bushings, replaced my end links and even tried replacing my hub assembly. What would be causing this noise? Im thinkin about having my ball joints replaced. Any ideas cause im going nuts with this rattling every litttle bump!!!
Old Jul 29, 2010 | 06:19 PM
powerstroke1869
bump
Old Jul 29, 2010 | 08:24 PM
jwhitetail's Avatar
jwhitetail
Get some heavy enough and stand on the tow hooks and jump up and down and get it going good, and look at the bottom of the shock were the bolt goes through and see if there is play, also the leaf spring eye's, and track bar. get it bouncing good.
Old Jul 29, 2010 | 10:07 PM
itsjustdan26's Avatar
itsjustdan26
Swaybar link kit?
Old Jul 29, 2010 | 10:48 PM
zx250's Avatar
zx250
Of the next Riffraff East
Pull your bolts out of the bottom side of your drop links, check for wear. I went though the same thing a while back and until I replaced the bolts, I couldn't get it to stop. Didn't look all that bad, but it did show some wear on the bolts. Haven't had an issue since.
Old Jul 30, 2010 | 06:15 AM
powerstroke1869
so where are my drop links and what kind of wear am i looking for on the bolts?
Old Jul 30, 2010 | 06:44 AM
zx250's Avatar
zx250
Drop links, end links, the two links that tie the sway bar to the frame. On mine, the bolts on the lower end, where it hooks to the sway bar wer worn enough to see, allowing enough slop to make the rattling, popping noise.
Old Jul 30, 2010 | 07:12 AM
riverrat41's Avatar
riverrat41
Had the same problem.Usually known as ''the clunk''.Like Barry said,changing all of those bushings should fix your problem.
Energy Suspension Parts Dealer, Specializing in Energy Suspension Bushings Suspension Components.
Old Jul 30, 2010 | 07:14 AM
riverrat41's Avatar
riverrat41
I have new bushings for the leaf spring eyes.What is the procedure for changing these out?Big time consuming job?Need a good press?
Old Aug 1, 2010 | 11:48 AM
powerstroke1869
well i found out my problem! Its my lock out hubs that were making all the rattling noise. So now its time to buy some warn hubs and forget about it
Old Aug 1, 2010 | 01:39 PM
dcf4x4's Avatar
dcf4x4
My warn hub makes that same sound so don't jump on the Warn bandwagon just yet.
One side I fixed by filling up space with an extra locking ring where normally only one should fit. The passenger side that makes the banging noise whenever I hit a bump did not get the extra ring since I bent it during removal of the old hubs.
Just my .02 cents.
Old Aug 1, 2010 | 03:55 PM
powerstroke1869
so then what did you do witht he passenger side? bcuz im not driving my truck everyday with that horriblerattling noise
Old Aug 1, 2010 | 07:24 PM
riverrat41's Avatar
riverrat41
Anybody changed these out yet????
Old Aug 1, 2010 | 07:47 PM
Ford79's Avatar
Ford79
My Milemarker hubs rattle too, the PS is worse than the DS. It is something I have learned to tune out. One of these days I'll get around to trying to stop the rattle.
Old Aug 2, 2010 | 08:22 AM
dcf4x4's Avatar
dcf4x4
the passanger side just bangs on every bump.
No visible harm but yeah, it's probably not good for it but the hub still works for now.
Phinxter
1983 - 2012 Ranger & B-Series
Apr 16, 2012 04:36 PM
sportsuburbangt
Jan 12, 2011 09:12 AM
BowtiedZ
Escape & Escape Hybrid
Nov 14, 2008 05:59 PM
stroke25
Aug 5, 2007 12:56 PM
