Dana Super 60 Front Axle
Funny you should ask. My point in trying to really nail it down is at some point I want gears and lockers and so I wanted to see what exactly I had. I didn't really think the F250/F350 had a Super 60. I thought it was a typo or something. So, in doing a bit of research I realize I sure do have a Super 60 and if I want the larger gears I can find exactly what I want 4.88 or 5.38, made by Dana/Spicer and the larger 10". So, when/if I do go with lower gearing I should be able to get the stock Ford parts for a F450/F550 for my F250 equipped Super 60.
So the Super 60 10" gears are only available in 4.88 and 5.13? I read online you could get a Super 60 from Ford Racing in 4.30s. '05 and up all have the Super 60 housings I read, but they don't all have the 10" gears. The bigger gears would definitely be the way to go with a lift and big tires.
Sorry cartmanea, yes, they are available in 4.30. I have the 4.30 Super 60 in my stock truck. If I go with lower gears I'll go with 4.88 or 5.38 which Ford/Dana offers in the larger Super 60 10".
Only the 2005+ V10 trucks with 4.30 or the PSD dually (Tow Boss with 4.30 gearing) has the Super 60 with the larger 10" gears. I don't know if the housings are all the same or not...I didn't think to check that.
The Super 60 is basically under all the Super Dutys with 4.30 and lower (numerically higher) gears. If you have a Super Duty with 4.30 you have the Super 60. If you have a F450 or F550 you have a Super 60.
not to b off topic but u had the pic up it reminded me of it(thanks for posting those pics Seminaryranger) . can anyone recollect (im a newbi to the front axle) on the front axle u have ur lockout hub then wheel hub assembly then ur u-joint now from there u have a rubber behind that is there a bearing? or can someone point me in the direction of a breakdown of it..OR.. between the lockout shaft and the u joint is there a a bearing in there where it goes into the housing? gotta vibration im tryin to nail down. but its somewhere in that area.. thankx for any help i can get
highlighted it in yellow
well i spent a good part of the day yesterday i just replaced the wheel hub assembly so thats taken care of the bearing on there was definitly shot. where the yellow x is there is play like something "should" be there and where the yellow circle is the dust cap is out..assuming i just push it back in then. wasnt sure if that was a seal or a bearing behing it.. my truck is a srw f350 sd 2004.. this is why ive always come to u all over the years for advice.. plus i love doin my own work.. hopefully one day i have a garage big enough to put my beast..lol
This is getting interesting for me, especially I'm in the lookout for a used Super 60 axle to put under my Class A Motorhome 4x4 conversion. So if either the 2005-up F250/350/450/550 have the Super 60, do they all have the same LENGTH axle? Does anyone here knows the WMS-WMS of a Super 60 DRW? I need one that is as wide as it can be.
#29
on
texinwa
Ford Truck Parts for Sale
02-14-2018 03:39 PM
blloyd29
1999 to 2016 Super Duty
03-28-2016 07:11 PM
