High Torque Starter
Old Jul 28, 2010 | 06:33 AM
cts1954's Avatar
cts1954
High Torque Starter
Anyone using a high torque starter. The stock starter just fits with my headers and exhaust and is really hard to remove so I want to make sure I don't have to once the body goes on. Any suggeastions?
Thanks
Old Jul 28, 2010 | 07:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
What engine are you running? I have a gear-reduction starter on my flatty V8 and it is as much better than the stock groaner as an alternator is compared to a generator. Zero problems since installed. It has to weigh 5 lbs less, too. You'll want to be 12v tho, and some re-wiring is needed (they hook up like a GM starter, solenoid is on the starter).
Old Jul 28, 2010 | 11:53 AM
cts1954's Avatar
cts1954
Ross
I have a 52 flathead converted to 12 volts as well. I have clearance issues around my headers so it should help. I see some on e-bay for sale, likely all pretty much the same. Also my stock starter seems to kick out all the time, should fix that problem as well.
Thanks
SuperDuty93
May 1, 2012 10:14 PM
Vern F110
Mar 14, 2012 11:17 PM
MUSKRATT2
Dec 13, 2009 11:36 AM
dryfly
13
Mar 31, 2008 06:07 PM
