Sponsored by: Kumho
Front drum brake question
Old Aug 17, 2007 | 09:30 PM
Broken40's Avatar
Broken40
I have a 73 F100 with manual brakes, and drums in the front... i was curious to know if i could add a brake booster to the master cylinder it it would help my brake sitsuation. any input would be severely appreciated. thank you in advance.
Old Aug 18, 2007 | 03:02 AM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
Unless you have trouble mashing down the brake pedal in my opinion just adding a booster would not make the brakes work better. The way I understand the booster, it only offers a vacuum assist to make it easier to apply the brakes. Pushing down harder on the manual pedal would have the same effect. At least that is the way I understand it. If I am wrong, someone please comment and let me know.
Old Aug 18, 2007 | 05:11 AM
rebocardo's Avatar
rebocardo
I had a 1971 F-100 4x4 with power brakes. I put in a complete booster/mstr cyl from a F-350 with disc brakes. Not 50/50 bias, but, you can adjust the rear brakes. But, even if you get the drum/drum combo the rebuilt is probably going to have a mstr for a disc set up anyways. Pretty much just a bolt in.
It made a hugh difference in stopping power, especially towing. With your manual brakes, it will be a 100% improvement at least.
I posted about in in the 67-72 forum a while ago.
Old Aug 18, 2007 | 07:24 AM
73F100*8Mile's Avatar
73F100*8Mile
It will help but you'll still have to stand on the pedal to slow the truck. You need to go to the yard and get a disc setup.
Old Aug 18, 2007 | 05:20 PM
Broken40's Avatar
Broken40
as far as the disc setup i have been told that all i would have to do is change out the outers from drum to disc...is that right.
Old Aug 19, 2007 | 04:21 PM
rebocardo's Avatar
rebocardo
If 2x4, that is basically correct and there are topics and even a tech topic on it ... I think.
If 4x4, no. You can go discs, just takes more effort and Chevy parts. Again there are topics on it in the 67-72 forum.
Old Aug 19, 2007 | 06:00 PM
Broken40's Avatar
Broken40
right on thanks ill look for more info there
1966 F-250
Nov 8, 2016 07:25 PM
fordf348
13
Nov 6, 2016 10:00 PM
Heritagechris
Oct 27, 2016 07:58 PM
tonyford
Escape & Escape Hybrid
Oct 7, 2012 08:31 AM
Tyler S
Oct 14, 2011 08:14 PM
