1978 - 1996 Big Bronco
Getting the spark plugs out
Old Feb 12, 2003 | 05:24 PM
dassmoof's Avatar
dassmoof
I'm having trouble unscrewing them. First of all I can't get a good grip and when I do they wont screw out. Also, I've got some aluminum around my spark plugs and on my exhaust manifolds. What exactly is it? It looked like it served no purpose so I bent it out of the way, then put it back.
Old Feb 12, 2003 | 06:00 PM
steve83's Avatar
steve83
"Grip"? Aren't you using spark plug socket? That, a few extensions, maybe a u-joint, & a ratchet always works for me.
The aluminum is heat shielding for the wire boots.
Old Feb 12, 2003 | 06:03 PM
AlM's Avatar
AlM
If the plug will move at all, you can usually remove it by working it slightly, sideways and back-forth.. You can also apply some wd 40 to try to lubricate the threads (as if I could on the passenger side plugs!). Also short piece of vacuum hose will help in tight spot when you get them freer.
Shuld be a cold engine when you do it too, but it's cold all over
ymirr
Apr 6, 2017 07:42 PM
tjs_79ford
Sep 20, 2009 11:30 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
mec2115
1997 - 2003 F150
Jun 4, 2006 09:19 AM
BlackHeaders
19
Nov 5, 2005 02:46 PM
