second battery?
Old Jul 26, 2010 | 07:33 PM
302flareside1992's Avatar
302flareside1992
second battery?
im gonna upgrade to an electric fan kit and an electric water pump. i have decided on a 200 amp alternator. would it be possible to run a second battery off of this 200 amp alternator. im also gonna be running about 8 offroad lights and i have to power an amp for a sub. is it possible to do this or is a second alt needed. any suggestions on how i can hook this all up
Old Jul 26, 2010 | 07:42 PM
Encho's Avatar
Encho
The Southernmost Mod
My recomendation: search in off-road forums, it's pretty common for winch users to install the kind of setup you want. You won't need a second alternator, the 200 amp alternator (mean green would be a great one) will be more than enough.
Old Jul 26, 2010 | 07:47 PM
302flareside1992
to power both batteries right?
and you know of any links to the offroad battery setups or should i just check the offroad forum on here
Old Jul 26, 2010 | 07:54 PM
86F150302's Avatar
86F150302
Yes very easy to run a second battery. Just mount where ever you want and run + to + and - to ground.
Use 1/0 gauge wiring and good fuses or circuit breakers.
200 amp alternator is fine with 2 or more batterys.
Upgrade your grounds for better voltage too.
Alot of bronco guys run dual battery setups
Old Jul 26, 2010 | 08:17 PM
302flareside1992
what is the canister on top of them?
should they be wired together as well?
Old Jul 26, 2010 | 08:23 PM
jplinville's Avatar
jplinville
I higher amp alternator will power what you need quite nicely.
Old Jul 26, 2010 | 08:31 PM
86F150302's Avatar
86F150302
Its a battery isolator.
I personally wouldn't use one in your case. Unless you have a winch..
How Does a Battery Isolator Work? | eHow.com
Old Jul 26, 2010 | 08:33 PM
302flareside1992
haha thanks for the extra link
that was my next question
Old Jul 27, 2010 | 02:10 AM
86F150302's Avatar
86F150302
NP bud.
You can always click the little heart next to someones post as thanks
Old Jul 27, 2010 | 03:50 AM
Duramaxfanatic1's Avatar
Duramaxfanatic1
and all this time i went through the trouble putting it on the other side, i even relocated my catch can and washer fluid reservoir.. i definitely like this setup better im glad i didnt cut any of that 0ga welder wire yet! i have a 200amp alt as well and am planning on a pretty serious stereo with a blow through box. just some other thoughts on needs for 2 battery's
Old Jul 27, 2010 | 08:35 AM
93_flareside's Avatar
93_flareside
Some easy reading about 200 amp'ers. I previously ran into a problem with my stereo, and found this. I'm not sure if its correct, but the more info the better I think.
RJM Injection Tech Why don’t you sell 200amp alternators?
Old Jul 27, 2010 | 11:53 AM
86F150302's Avatar
86F150302
If your doing a blowthrough just throw the batterys in the bed.
Funke1
Electrical Systems/Wiring
18
Oct 4, 2014 07:25 PM
krewat
Modular V10 (6.8l)
15
Mar 7, 2012 09:32 PM
Visseroth
Feb 10, 2012 09:29 AM
03BLKEB
May 6, 2009 02:05 PM
body9599
1978 - 1996 Big Bronco
Apr 6, 2005 12:19 PM
