im gonna upgrade to an electric fan kit and an electric water pump. i have decided on a 200 amp alternator. would it be possible to run a second battery off of this 200 amp alternator. im also gonna be running about 8 offroad lights and i have to power an amp for a sub. is it possible to do this or is a second alt needed. any suggestions on how i can hook this all up
My recomendation: search in off-road forums, it's pretty common for winch users to install the kind of setup you want. You won't need a second alternator, the 200 amp alternator (mean green would be a great one) will be more than enough.
and all this time i went through the trouble putting it on the other side, i even relocated my catch can and washer fluid reservoir.. i definitely like this setup better im glad i didnt cut any of that 0ga welder wire yet! i have a 200amp alt as well and am planning on a pretty serious stereo with a blow through box. just some other thoughts on needs for 2 battery's
Some easy reading about 200 amp'ers. I previously ran into a problem with my stereo, and found this. I'm not sure if its correct, but the more info the better I think.
If your doing a blowthrough just throw the batterys in the bed.
