rear disc conversion
Permatex/Ultra disc brake lube | Brake Lube | AutoZone.com
Just kidding: I've seen a lot of good, common, mechanical sense in your posts in the past. I'm pretty sure you and I are on the opposite sides of the political spectrum, as I'm a LIBERAL (as opposed to BOTH Dems and Repubs), but there's no denying that you know your stuff, re: "our" trucks.
Good advice (cleaning and PROPERLY LUBRICATING the drum brake compoenents). Infrequently given advice and even less followed, IME.
Properly lubed and adjusted drum brakes can be effective, as long as one is not roadracing in mountainous conditions, where heat-caused "fade" becomes a problem. Consider how many Ferraris, M-B's, Maseratiis, etc..., did roadracing into the '50's, at speeds well in excess of what our pedestrian trucks can achieve, on mountainous, twisting road courses...with DRUM BRAKES.
Like paint, preparation in brakework is 90% of the battle.
Listen to Lew--he knows.
Big Six
P.S. Even in a sedan (which has MORE weight on the rear axle, than our trucks, relatively-speaking, the rear brakes do a MAXIMUM of 30% of the work. Therefore, the earlier estimate in this thread, where someone said the rears do only 20% of the braking work, could very well be correct.
I found a great improvement in the braking of my 1981 F-100 simply by adding a POWER BRAKE BOOSTER, for those that might lack this option. And, contrary to popular belief, even though the rear drums are different sized when a booster is optioned (I think boosted brakes have a 1" smaller drum) I had ZERO premature lockup issues, after adding the booster. I also had a heavy, fiberglass cap on the back, so that may have helped.
I have a '08 2500 hd that has disc rears, I know that its newer and blah blah blah and a chevy. But, I have over 92k on it, and have yet to do the brakes (front or rear). Do you think that its the difference in weight dist, newer tech, or what. I was told by the chevy technician that it has to do with the rears never needing to be adjusted, to keep them in correct pressure... Once again just curious.
