Installing the IC.
Old Jul 26, 2010 | 12:56 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question Installing the IC.
Im in the process and I need to change (longer) the hoses for the tranny cooler, what specification of hose do I need.
Thanks.
Old Jul 26, 2010 | 01:04 PM
427 fordman's Avatar
427 fordman
I just went to the parts store and got regular tranny hose. Nothing special about it.
Old Jul 26, 2010 | 01:07 PM
superduty4x4's Avatar
superduty4x4
I believe the stock trans lines on the OBS are 5/16", SD is 3/8".
Old Jul 26, 2010 | 01:20 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thank you amigos, but I was looking for the meets specs number, for instance: the fuel hoses meets SAE J30R9 specs
Old Jul 26, 2010 | 01:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
I found this number: meet OEM and SAE J1532 requirements Is that correct?
Old Jul 27, 2010 | 09:22 AM
superduty4x4
Can't help you there... just make sure whatever you buy is rated for trans fluid.
Old Jul 27, 2010 | 11:25 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Gracias amigo Chase. I will do what you told me.
Old Jul 27, 2010 | 11:35 AM
pjwoolw's Avatar
pjwoolw
Here is a link you might find interesting. Seems the hose needs to be rated for about 250 degrees. (on edit) The sae30r9 is rated to 275 degrees. Still looking for the specs on it.
Old Jul 27, 2010 | 12:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Pete,
well that is the same number I got (J1532), but Im confused about the automatic transmission fluid they mention: A, B, AT, and BT?, wich one is of our transmissions: maybe AT (-40 to 302 degrees F)?
Thanks amigo.
Old Jul 27, 2010 | 01:31 PM
pjwoolw's Avatar
pjwoolw
Seems to me either one will be OK for the cooler.
This SAE Standard covers four types of hose for use with automatic transmission fluid.
A, B, AT, and BT.
Type A and Type B are for use within a temperature range of -40 to 125 degrees C (-40 to 257 degrees F).
Types AT and BT are for use within a temperature range of -40 to 150 degrees C (-40 to 302 degrees F). Recommended maximum operating pressure for Type A and Type AT hose is 1.7 MPa (250 psi).
While recommended maximum operating pressure for Type B and Type BT hose is 1.0 MPa (150 psi). The lower pressure (Types B and BT) hose is for auxiliary cooler applications only.
The reference fluid for tests requiring the use of automatic transmission fluid shall be Dexron-II E/Mercon or equivalent.
Old Jul 27, 2010 | 03:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
A, B, AT, and BT.
Ok, thank you, I missunderstood type hose for type of fluid , but now is clear for me too.
Old Jul 27, 2010 | 05:03 PM
superduty4x4
Good info in this thread... nice job Pete!
Old Jul 27, 2010 | 07:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Ditto
X2 on that. Rep sent.
Pete Kildow
Large Truck
Nov 5, 2013 10:19 PM
tiger_698
Feb 10, 2009 10:09 PM
Brown Falcon
Jan 1, 2009 02:29 PM
Blackwaterforge
Feb 6, 2006 05:02 PM
donb_1
1983 - 2012 Ranger & B-Series
Feb 8, 2000 12:49 AM
