Holley carb help needed
Old Jul 25, 2010 | 08:24 PM
77-250's Avatar
77-250
I'm rebuilding a 600 CFM Holley vac secondary carb and I need some help with the accelerator pump discharge nozzle. I believe I lost some pieces. If you remove the screw and the discharge nozzle there should be a pointed valve like looking piece, then a roll pin type piece and then a small ball right? I think I lost the roll pin and the check valve piece (pointed piece). The diagram shows a small ball, and a ball weight, it looks like a roll pin? And then the pointed piece, right?
Thanks
Old Jul 25, 2010 | 08:28 PM
steponit's Avatar
steponit
Holley Performance Technical Service Department
Old Jul 26, 2010 | 10:15 AM
DeepRoots's Avatar
DeepRoots
careful man... the diagram isn't correct for all models.
some (like my 1850) just have the needle valve, nozzle and screw. oh and two lil gaskets.
If you were to put a ball in there you would break something.
Old Jul 26, 2010 | 11:51 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Only the very early Holley carbs used the ball and weight. The newer ones all just use the pointed weight.
Old Jul 26, 2010 | 06:56 PM
77-250's Avatar
77-250
Thanks, mine is a 1850-3.
navistarnut
Sep 3, 2015 11:08 PM
UZI-SUICIDE
46
Jun 1, 2013 03:28 PM
harris2108
Jan 9, 2009 10:17 AM
svooom
19
Mar 8, 2006 05:11 PM
Kundalini
Jan 14, 2004 01:22 PM
