AOD shaking?? in 3rd gear
Old Jul 25, 2010 | 08:01 PM
ozblitz's Avatar
ozblitz
My truck just started to shake when I go from OD and slow down to about 25mph. As I start to accelerate slowly No down shift. it starts to shake really bad? Anyone know what causes this? Is it the tranny or eng? If I go faster it down shifts and it doesn't do it. It only does it when it doesn't downshift. The tranny has less than 10k mi. on rebuild. Any help would really help.
Old Jul 25, 2010 | 11:02 PM
85e150's Avatar
85e150
TV cable installed and adjusted correctly?
Old Jul 26, 2010 | 07:17 AM
Lazy K's Avatar
Lazy K
What 85e says. However when was the last tune-up? Have you checked for vacuum leaks around the engine?
Old Jul 26, 2010 | 07:51 AM
ozblitz's Avatar
ozblitz
well funny you ask. The eng. was installed 1 yr ago and it was running fine. So I don't see how the TV cable would be wrong? As for the vacum leaks I'm sure it may have some but again it was running fine. Its a 90 mustang power train in a 79 Ford truck. So that's why I say it may have a vacum leak here or there. Everything was retro fitted for this truck. I haven't done a tune up since the eng. was put in.
Old Jul 26, 2010 | 02:47 PM
85e150's Avatar
85e150
Any and all linkages, cables etc should be checked. The TV cable/linkage is critical to trans life.
Also the basic vacuum leak and tune-up checks should be done.
Sometimes conversions and adaptations have durability problems or adjustment issues, etc, and can have these kinds of issues at low miles.
Old Jul 26, 2010 | 05:49 PM
ozblitz's Avatar
ozblitz
Thanks for your help. I'll take it to get it checked out.
Old Jul 28, 2010 | 05:37 PM
ozblitz's Avatar
ozblitz
update
Guys you ain't gonna believe how simple this was?? The mechanic said the firing order was off and #7 plug was fouled up. Installed new plug, set right firing order and runs like a champ.
Old Jul 28, 2010 | 11:59 PM
85e150's Avatar
85e150
Do check the TV cable adjustment, just make sure it was done right.
bassinbick
1997 - 2003 F150
Oct 27, 2016 07:18 PM
Blmorre
Dec 28, 2012 01:37 PM
KristinHuff
Oct 14, 2011 09:42 AM
robs01f250
May 16, 2011 01:18 PM
