Haunted Excursion??
Old Jul 31, 2010 | 02:05 PM
  #31
Dr.Detail.TN's Avatar
Dr.Detail.TN
I had a similar problem with my 97 Mustang. I took it to Autozone and they checked the alternator 3 times with their digital tester and kept telling me it was good. I then took it to Advance Auto and their tester was not a digital. When they did their test it showed bad. I got a new alternator and all was good. I would just about bet it is the alternator. I would take it somewhere else and get it checked out.
Old Jul 31, 2010 | 04:39 PM
  #32
code_red's Avatar
code_red
good to see all is working well so far dakrri. I have since spoken to a gentleman who has work on fords now for a very long time. He asked me this" did you recently change the brakes" i said yes the front brakes. The drivers side caliber went bad and wore out the rotor. He said' Check your ABS sensor. He said this with confidence . So now im making my diagnoses. its either one of 2 things. abs sensor (that is if it is on the front brakes ) or 2 the alt. Thanks all for the input!!
Old Jul 31, 2010 | 10:31 PM
  #33
Stewart_H's Avatar
Stewart_H
Originally Posted by Dakrri
Then I got the bright idea to change the Serpentine belt as long as I was in there.....MAN what a pain the butt that was.
Ok, I'm not trying to be an azz here, but how the heck could changing the belt be difficult?
Why was it such a PITA for you?
Stewart
Old Sep 12, 2010 | 08:45 PM
  #34
code_red's Avatar
code_red
Just an update here. I have been slaking off on fixing my little issue what i started out with so i decided to work on it today. I took both front wheels off, along with the rotors to clean/inspect the abs sensors. They were all greased up. I cleaned them and put it all back together and test drove it. I still having the same issues as before. I beleive my next fix will be replacing the alternator. Its only making sense to me to do this, even though advanced auto tells me that it checks ok. Just throwing guess's in the wind here.
Old Sep 13, 2010 | 08:50 AM
  #35
Dakrri's Avatar
Dakrri
Just an update:
On 7.31.2010, I replaced my alternator with a 200 Amp High Output Alternator from DB electric, both batteries that are/were under warranty, and the serpentine-belt. I have not had any other issues….all is good.
dakrri
Old Sep 13, 2010 | 07:11 PM
  #36
code_red's Avatar
code_red
Thanks for the encouragement dakkri.Im gonna see about getting it on the truck this weekend. any clue as to the price on them, a general ballpark figure?
Old Sep 14, 2010 | 08:16 AM
  #37
Dakrri's Avatar
Dakrri
Ford Excursion 200 Amp High Output Alternator Diesel 03 04 05 8306 from DB electrical Price: $209.95 No core charge or exchange. 3-day delivery
$50.00 for the new serp belt
Batteries were under Warranty
Good luck.
Old May 7, 2011 | 10:01 PM
  #38
oceanfiveo's Avatar
oceanfiveo
I had a very similar electrical issue in my diesel excursion. Check the two little dinky wire that plug into your alternator. I wound up replacing the delayed accessory relay as well (that fixed the crazy gauge issue). Not sure if the charging systems are exact but I would venture to say they are close.
20powerstroke02
Jul 25, 2016 07:23 PM
frosty95
18
May 13, 2016 09:21 AM
Fractalcathedral
Modular V10 (6.8l)
Sep 26, 2015 02:11 PM
Boodrow379
Apr 20, 2015 05:29 AM
Harrison Dickie
6.4L Power Stroke Diesel
Feb 15, 2012 06:25 PM
