1978 - 1996 Big Bronco
Air Induction. HELP!!!!!
Old Feb 12, 2003 | 08:46 AM
VIBR8R's Avatar
VIBR8R
Question Air Induction. HELP!!!!!
I am wanting to put a new air induction system on my 96 xlt 5.0. I am thinking of the K&N system but, I am not exactly sure if I have mass air or not. How do I tell? And, does anyone have any suggestions as to what type of system would work best for trying to improve my awsome 11-12 mpg?
Gas Prices Suck
Old Feb 12, 2003 | 11:30 AM
greystreak92's Avatar
greystreak92
Check out project MPG at www.performanceunlimited.com they came up with some interesting findings when they researched induction systems.
Your 96 should most likely be mass air. There is a sensor between the air filter box and the intake hose on a mass air engine. The sensor will have a wiring harness attached to it to send info back to the computer. I would think that this is the most obvious way to visually inspect for mass air. My '92 is speed density and doesn't have this sensor in the unduction system. While I am not certain, I was under the impression that mass air became standard after a certain point in time. Unfortunately, I don't know when in the Bronco production run that was.
Old Feb 12, 2003 | 11:00 PM
nbtvee61's Avatar
nbtvee61
My 95 has mass air and it looks just like what Graystreak described. I would almost be certain that your '96 has it also.
Old Feb 13, 2003 | 07:35 AM
steve83's Avatar
steve83
All '96 4.9Ls, 5.0Ls, and 5.8Ls were MAF. The only gas truck engine that was still MAP in '96 was the 7.5L, but CA versions might have been MAF.
Old Feb 13, 2003 | 06:51 PM
VIBR8R's Avatar
VIBR8R
where can I find project MPG within that websight?
Old Feb 13, 2003 | 09:08 PM
steve83's Avatar
steve83
http://www.performanceunlimited.com/projectmpg/
