1978 - 1996 Big Bronco
Shuttering, random problem
Old Feb 11, 2003 | 09:55 PM
dassmoof's Avatar
dassmoof
About a week or two ago my Bronco randomly started acting as if I swapped in a 3 Cylinder Geo engine. It has no power at all and even when floored struggles to get up to 30MPH. After about a minute and a half it'll finally hit 30 after my flooring. It also refuses to shift unless I take my foot off the gas. I took a look at my carb but it seems to be alright. This problem is making me incredibly mad, the truck has no go. It just wont get out of its own way and the problem started completely randomly. I was going to school one day and all of a sudden it started and just got worse and worse.
Old Feb 12, 2003 | 07:16 AM
Chrisvte's Avatar
Chrisvte
You might consider checking your exhaust system. A lot of times, a clogged catalytic converter will create that problem. Since your engine must have an open exhaust, it can't make power with a restruicted exhaust flow. Your transmission will not shift also because you have the accelerator florred. Try checking it out and let us know.
Old Feb 12, 2003 | 05:23 PM
dassmoof's Avatar
dassmoof
My cat is hollowed out, and my transmission shifted around 2.5k maybe a little higher, now it wont shift until 3.1k+ if it even does at all.
Old Feb 12, 2003 | 08:31 PM
Chrisvte's Avatar
Chrisvte
Well, you might think about checking out your timing chain. I recently drove mine across country and ran into a similar problem. It turned out that i actually had 2 problems. The first being that the idiot first owner of the truck replaced the engine and didn't align the timing marks on the crank and cam. The second problem that created the "no power" problem was that my timing chain had "stretched" and wore out. Once I replaced the chain and correctly aligned the timing marks, it runs like a dream! I know you probably hate the idea of doing that, but it might be the problem. I can't think of anything else that would create that problem. Let me know what you find.
Old Feb 12, 2003 | 09:17 PM
bronco cam's Avatar
bronco cam
Could be lots of other things. Pluged fuel filter, bad plug wires ,bad plugs, bad injector etc.
Old Feb 12, 2003 | 11:17 PM
dassmoof's Avatar
dassmoof
I've figured it out a little more. It's not the fact that it has no power (Although it seems that way). It seems to not be shifting at all. If I pump the gas it'll shift and act fairly normal except for a really hard shift. I need to pump the gas once to get it to shift up or down. Plus, it idles incredibly low while in D, like around 500RPM, it gets close to dying. I'm thinking it's a vacuum hose
Old Feb 13, 2003 | 07:37 AM
steve83's Avatar
steve83
What engine/transmission?
Old Feb 13, 2003 | 04:48 PM
dassmoof's Avatar
dassmoof
I've got a 351 H.O. w/ E4OD (I'm danged sure it's the one I've got. I don't have any of my codes, so from descriptions I think this is it.)
Old Feb 13, 2003 | 05:29 PM
steve83's Avatar
steve83
If you have a factory carb, you don't have an E4OD. It's an electronic automatic, and is controlled by the EFI computer. Check here. The E4OD can also be identified by the electrical connector on each side of the pan and the O/D kill button either on the dash ('87-?91) or on the end of the shift lever (?92-96).
Old Feb 13, 2003 | 07:51 PM
Big 89 Bronco's Avatar
Big 89 Bronco
On my 89 there isn't a o/d kill its an actual drive selection on the transmission, next to it is regular d. My guess would be to check spark plugs and wires. Maybe you could look at the fuel filter or fuel pump, there could be a clog in the line (it could happen). Have you checked you transmission fluid lately? Thats just my guess.
Old Feb 13, 2003 | 09:09 PM
steve83's Avatar
steve83
89
Yours is an AOD, not an E4OD.
