carb size
Old Jul 25, 2010 | 01:57 PM
ryan f150 4x4's Avatar
ryan f150 4x4
carb size
hey guys what size card should i put on my 390 its got a edilbrock highrise intake ?? its got a 650 holly on there it runs ok but would i get more jam out of it with a biger carb
Old Jul 25, 2010 | 03:51 PM
7Ford6's Avatar
7Ford6
Everyone here has their own carb preferences..... Dial in what you have first.... Then play with different combo's as time and cash allows...
I'm running a 800 cfm qjet on my 390 and love it... The rochester quadrajet is a varible cfm carb and will only flow what the engine requires. Gm used them on engines from the 305 all the way up... Ford even used them in '70 and '71 on the 429... The qjet's small primaries are more than enough for daily street driving with great economy + the added bonus of the huge secondaries for those times you want to have some fun.. To set it up right, check out - Cliffs High Performance Quadrajets :: Qjet Carburetor Rebuild Kits, Parts, Bushing Kits, Carb Tuning - buy the book, and read it twice.....
I did use a Edelbrock #1483 ford kick down linkage adapter to make the carb work on my automatic application or you may use a lokar kickdown cable kit. I also used a 4 hole adapter plate Trans-Dapt 2034 flipped over and modified slightly to fit.....
Whatever you end up running, get a vacuum gauge and dial it in for highest vacuum for the best <nobr style="color: darkblue; font-weight: bold; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_20_0">performance</nobr> and economy... How to Use and Interpret a Vacuum Gauge...
Then, just enjoy the ride....
Old Jul 25, 2010 | 09:06 PM
Rockstone's Avatar
Rockstone
Unless you are turning major RPM's you have enough carb. This might help.
Holley Performance Technical Service Department
Old Jul 25, 2010 | 09:49 PM
kendooley's Avatar
kendooley
Rockstone's right.
Rockstone is right. A 600 is enough carb for a 390. You won't get anymore juice with a bigger carb, just worse fuel milage. Are you still running the stock exhaust manifolds? If so, get headers to gain more power. The stock manifolds don't flow well at all.
Old Jul 26, 2010 | 09:18 PM
ryan f150 4x4
cool thanks guys i gota do a compression test first its smokein pretty good .And yes i want some majer hp from this truck it will bearly spin the tires
JimsRebel
Jun 8, 2008 10:16 AM
mikedeason
Apr 2, 2007 10:38 AM
Fireman1212
Aug 6, 2006 10:32 AM
MRStace84
Sep 27, 2004 07:08 PM
200000+F150
Jul 2, 2003 06:15 AM
