Holley 390 jet size
They should be stamped on them. If you believe it is running rich I would rebuild it. You have to pull the float bowl off to replace jets so you might as well spend the 20 or so bucks for a rebuild kit. This will give you a new float and power valve. Also make sure your choke is shutting completely off. If the carb is stock specs their is another problem causing it to run rich. Just changing jets may be a temporary fix but I recomend a rebuild with the factory jets before just swapping pieces and parts to see what works.
T. Roberts
UFD Local 1147
T. Roberts
UFD Local 1147
T. Roberts
UFD Local 1147
T. Roberts
UFD Local 1147
The Carb is brand new.
Oh yeah, that carb comes with 50 main jets. I've got sets of jets 45's thru 102's for my tinkering, but again the jets only limit fuel flow at or near WOT. You might try changing the power valve to a lower number or try a duel stage power valve. They are expensive but do help trucks get better fuel economy with out losing top end power. If you put a duel stage power valve in or if your carb is not equipped with one install a power valve backfire protection valve.
daveengelson
11-05-2016 09:33 AM
hooler1
01-16-2016 08:52 PM
AbandonedBronco
93
03-21-2014 11:14 PM
