Rear axle shaft
Jul 25, 2010 | 12:48 PM
Rear axle shaft
ok guys.. this morning my axle shaft bearing broke etc...
so i go t a new axle shaft bearing to replace it tomorrow, is there any like clips that hold the axle shaft in? cause i woulda broke them too...
SEE?!?!?!!?
Jul 25, 2010 | 01:45 PM
Yes there are C clips that hold the axle in , its an 8.8 right ? you will need to pull the cover & have a look...Lew
Jul 25, 2010 | 01:47 PM
ok... so the chances are that i broke the Cclips also? along with the bearing?
and yeah its a 8.8".
Jul 25, 2010 | 01:50 PM
Yeah something broke in there..
Jul 25, 2010 | 01:52 PM
**** MY LIFE!!!!!!!!!!!!!!!!!!!!!!!!!!
this is the last thing i needed....
the thing that pisses me off the most is that this rear axle was rebuilt 10k miles ago... but idk by who, as i bought it off someone...
Jul 25, 2010 | 02:34 PM
The side axle should not come out even if the outer bearing fails, looks like something broke. Considering you are also planning an engine upgrade you should consider adding C-clip eliminators so this type thing doesn't happen again.
Jul 25, 2010 | 05:07 PM
Jul 25, 2010 | 05:24 PM
Need to see pics inside the cover...
Jul 25, 2010 | 05:36 PM
i havent gotten to that yet... im doing that in the morning...
Jul 25, 2010 | 07:29 PM
Least no one will drive it off before you get back there.
Jul 25, 2010 | 07:33 PM
Quote:
Originally Posted by
SaikotikGunman
You sure know how to hurt a guy!!!!!!
Jul 26, 2010 | 04:27 PM
well its in the shop now... i popped the diff cover off and stopped there... i wasnt gonna go any further... looks complicated cause it is complicated...
i took pics but accidently left my camera in the truck... will get it later when i stop by the shop...
Jul 26, 2010 | 05:59 PM
Well nows the time to upgrade , if it needs a new differential or axles , good time for a gear swap to ..don't want to wast the labor....Lew
Jul 26, 2010 | 06:08 PM
lew52
ive got 4.10s in it... why would i swap gears?
Jul 26, 2010 | 06:23 PM
Well then your good on the gears ,,,,
