General Diesel Discussion
Tranny problem and Front end problem
Old Jul 25, 2010 | 11:48 AM
dthompson's Avatar
dthompson
Went to change my tranny fluid and couldn't get the plug out it just turned a million times. so i did it the old "showering way". so while i have the pan off i'd like to figure out why the bolt wouldn't come out. When i pull the magnet off there is a little ring on the bolt that turns that i'm guessing isn't supposed too. Then there has been a horrible vibration or shake in my front end. lost a wheel bearing bout 6 months ago then bout 3 months ago had all new ball joints. pulled the caliper to check if the other wheel bearing was loose and got no movement so i went ahead and had the rotors turned while i had them off. noticed the bolts taht hold the calipers on one bolt on the pass side had 2 washer like things and the othershad none! wouldnt this make the caliper crooked? thanks for any help guys! thanks
