Re: P1151
Old Jul 25, 2010 | 09:28 AM
charlie268's Avatar
charlie268
Re: P1151
Sorry I didnt post everything needed on my last post on this subject. I have a 2000 ranger, 4wd, extend cab, 4.0 , auto. As I said in my last post I got a cel and took it to my service station to see what the code was. Got P1151, the mechanic reset the code and 2 days later it came back on again. Like I said before it drives fine and the only thing that indicated something was wrong was the mileage dropped 2 to 3 miles per gallon. I have in the past 6 months replaced the tps, iac, cleaned the maf, changed the fuel filter, and cleaned the throttle plate. Now this morning I started the truck to go to the store and the cel went out. I drive this truck to work every day and round trip is 110 miles so I check the mileage every day. One thing I should add is last fall when I changed the fuel filter I was getting a running lean cel. After changing the fuel filter starting after warm requires me to turn key on and wait a few seconds to start it. If I try to start it right away it just cranks for a while before starting.
Old Jul 25, 2010 | 10:55 AM
Eaglefixer's Avatar
Eaglefixer
have you changed your o2 sensor yet.
Old Jul 25, 2010 | 11:59 AM
charlie268's Avatar
charlie268
Yes the downstream one I did. thats when I was getting a running lean code and I replaced the downstream one and the fuel filter. This time no other code but P1151
oachs83
Mar 6, 2022 12:51 AM
rustybuttrusty
3.8 & 4.2L V6
Feb 2, 2016 03:39 PM
MarkFord34
1997 - 2003 F150
Nov 6, 2013 08:09 PM
ford150ford350
Mar 3, 2013 03:28 PM
pete315
Jun 22, 2008 05:16 PM
