middle console rattle
Old Feb 12, 2003 | 05:47 AM
coachhomer's Avatar
coachhomer
Question middle console rattle
Hey all, my wifes 97 explorer rides like a beach buggy and the center console shakes and rattles like crazy.
Any ideas how this thing is connected and can I bolt it down a little harder?
It only shakes at high speeds. Anyone got any ideas why this thing shakes like this? It doesnt need an alinement.
Any help would be appreciated
Scott
Old Feb 15, 2003 | 07:25 PM
coachhomer's Avatar
coachhomer
no one has an answer for this ? I thought someone would be able to help
Scott
Old Feb 16, 2003 | 02:04 AM
e_no_g's Avatar
e_no_g
I can only say that when mine was making a rattling noise, I found that it was the covers towards the back on each side of the console, they are oval in shape. They werent in tight enough, so I just folded a piece of paper a little thick and stuck it between the cover and the console. Cant even notice it, and it fixed my problem.
Old Feb 18, 2003 | 09:59 AM
fetterjohn's Avatar
fetterjohn
I had the same problem with my console in my '97. I took the whole thing apart...including the cd changer and all the inside. It took a while, but there are a couple of brass nuts that needed to be tightened down a bit. It made it a little bit better, but it still rattles and shakes side to side when going over diagonal obstacles or high speed on bumpy freeway. Give yourself some time to do it...and remeber where things go. Good luck!
Old Feb 18, 2003 | 12:40 PM
reberhardt's Avatar
reberhardt
Here is the Ford repair (the part # is towards the bottom):
Console - CD Player Skips/Squeaks/Vibration
Article No.
97-26-21
12/22/97
^ CD PLAYER - "SKIPS" - HIGH SERIES CONSOLE -
NORMAL DRIVING CONDITIONS
^ NOISE-"SQUEAKING" FROM HIGH SERIES
CONSOLE - NORMAL DRIVING CONDITIONS
^ VIBRATION - HIGH SERIES CONSOLE - NORMAL
DRIVING CONDITIONS
LIGHT TRUCK:
1995-98 EXPLORER
1997-98 MOUNTAINEER
This TSB article is being republished in its entirety to include 1998 model year vehicles.
ISSUE:
A shake/vibration from side-to-side of the high series console may occur on some vehicles under normal driving conditions. The shake/vibration could cause "squeaks," "rattles," and CD player skips. This is caused by low clamping load of the rear attachment bracket on the console to floor pan.
ACTION:
Install a bracket to the existing floor bracket and attach it to the internal structure of the console. Refer to Instruction Sheet 7207, included in the High Series Console Floor Bracket Kit, for details.
SERVICE PROCEDURE
(F77Z-78044N19-BA) contents are as follows:
^ One (1) Console Brace
^ Four (4) Tapping Screws - M6.3x1.81x19 Hex Washer Head
^ One (1) Instruction Sheet (I.S. 7207)
Obtain locally one (1) Devcon Polystrate 5-Minute Epoxy.
PART NUMBER PART NAME
F77Z-78044N19-BA High Series Console Floor 8racket kit
(Obtain Locally) One (1) Devcon Polystrate 5-Minute Epoxy
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 97-5-14
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
972621A Install High Series Console 0.7 Hr.
Floor Bracket Kit
972621B Additional Time To 0.2 Hr.
Resecure Mounting
Bracket
DEALER CODING
CONDITION
BASIC PART NO. CODE
7804SA06 59
OASIS CODES: 107000, 207000, 702000, 702300
Kelly Crerar
2009 - 2014 F150
Aug 27, 2016 06:22 PM
Tugly
22
Nov 17, 2015 10:33 AM
Fosters
Oct 31, 2008 10:04 AM
offshore1
Aug 2, 2007 06:24 PM
buckcreek
Feb 24, 2005 08:16 AM
