DVD Install - Can you help ?
Old Jul 24, 2010 | 11:45 PM
Michael-2001Ex's Avatar
Michael-2001Ex
Lightbulb DVD Install - Can you help ?
Hey all:
I just got a 2001 excursion. To the best I have been able to tell, The rear entertainment pkg was not offered until 2002. So being either brave or really stupid, I located the package on ebay and ordered it. I have seen 2 versions of the system, one have the IR headphones with the "eyes" mounted in the corner of the console itself. The other version does not have "IR EYES". Now this is where I am confused....When I ordered the package it included 2 headphone and the wiring harness "both male and female ends"..Assuming that is for the Heat/AC controls and the only thing the player needs is +12V and the GND. Which will allow the audio from the DVD to play on the IR Headphones and not requiring the headunit (cd-6) to be altered and not having to pull wires thru the headliner and down the column and to the back of the head unit....is this correct or am I just being hopeful..In 2001 that package was not offered in that vehicle ( I think) and if it was, how would I tell if my radio is compatable ?
And last question...any opinions on how this will get mounted? Is the a beam going across the roof?? Or am I just being hopeful again?
AM I IN TROUBLE AND DID I WASTE THE $$ ON THE CONSOLE ??
Any info is VERY Helpful !!
Old Jul 25, 2010 | 04:29 AM
Ruby's X's Avatar
Ruby's X
I have an 03 that didn't have the DVD. I removed the rear heat/ac control and screwed my in there. I wanted the DVD's sound to play thru the trucks speakers so I got the audio interface that plugs into the cd head unit, no cutting wires. And it's not that hard running the wires the way you said That's what I did.
Old Jul 25, 2010 | 05:21 PM
Michael-2001Ex
Was it the factory ford console you installed?
Can I use mine without the adapter/interface?
that will give audio thru headphones only?
how do I know if my radio is compatable should I want to use it thru the speakers?
Where Can I get the adapter/interface ?
Do I ask to many questions ???
Thanks again,
Michael
Old Jul 25, 2010 | 07:57 PM
Michael-2001Ex
After further research, this is what I have...
cd6 on self test it produces error codes of u2003 cddj u2008 phone u2005 ricp
I have a 20 pin connector of which 17 pins are empty - 3 used are BRN LT Blue/Red Green/Black
Old Jul 25, 2010 | 08:22 PM
Michael-2001Ex
I Have info if this helps anyone...Ford Radio Part Numbers and there options listed by year and model...
http://www.issford.com/issford/radio_guide.pdf
of course my radio is not listed...some numbers are close but not exact, i you part number is 1C7F-18C815-AA
It also shows how the 2nd and 3rd numbers show the vehicle is was used in..
superdave02f552
Mar 8, 2016 03:43 PM
Keri Jenkins Dailey
Sep 8, 2014 06:29 PM
powerkmac
Apr 25, 2014 07:48 PM
Technologiq
Sep 26, 2013 06:02 PM
Bford1022
Jun 14, 2013 11:29 PM
