BulletProofing Tactics Article
Old Jul 24, 2010 | 02:21 PM
az4x4bronc's Avatar
az4x4bronc
I just got my September 2010 copy of FOUR WHEELER magazine. It has a good article about BulletProofing the 6.0. It has all the usual oil cooler and EGR failure information. It also mentions something I didnt know about, Head problems. It mentions the weak valve seats in the heads and that they are prone to cracking, even for low milage unmodified/stock engines. I have read about the ARP head stud fix but the weak valve seat problem is new to me.
Old Jul 24, 2010 | 02:35 PM
cheezit's Avatar
cheezit
Ive worked on them everyday pretty much sence 2003.... you that info would be new to me as well.
there was an artical awhile back about its common for a 6.0L to break a crankshaft. at that time I had never seen one do it. To this day I have seen one of those.
so ya what ever....
Old Jul 24, 2010 | 04:56 PM
az4x4bronc's Avatar
az4x4bronc
Thanks for the input cheezit.
Here is a quote from the article about the coolant filter effectiveness:
'To solve the coolant restriction issue, many companies offer aftermarket coolant flitration devices... While these units do in fact remove contaminants from the cooling system, they do not address the corrosion issue common to aluminum heat exchangers and coolant."
Coolant filter dosent help?
Old Jul 24, 2010 | 05:03 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Corrosion isn't a problem if you maintain the proper mixture of the proper coolant.
Old Jul 24, 2010 | 05:05 PM
cheezit's Avatar
cheezit
aluminum heat exchangers ..... huh. last I checked the heat exchanger is stamped steel with an aluminum cover that is nothing more then a cover.
Old Jul 24, 2010 | 05:48 PM
az4x4bronc's Avatar
az4x4bronc
I think they are trying to sell the reader on Bulletproof Diesel's external mounted oil cooler. They say thats a better solution than the coolant filter. It is defenetly much more expensive.
djmechanic
Jul 12, 2016 12:31 AM
shizzu
Jan 27, 2016 11:13 AM
KLK04
Jan 19, 2016 12:46 PM
Krooks12
Jan 2, 2015 07:06 PM
clevelandtundra
Aug 27, 2012 11:26 PM
