Need help with 1996 Ford Ranger codes!!!
Old Feb 11, 2003 | 09:09 PM
jvr4210's Avatar
jvr4210
I am seeking information on the following codes:
1.) P1443 System Control Valve. What do I need to repair/replace in order to clear this code?
2.) P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control. What do I need to repair/replace in order to clear this code?
Please respond to "jvr4210@swbell.net" before Thursday.
I thank you in advance for any help here.
Old Feb 11, 2003 | 09:29 PM
EPNCSU2006's Avatar
EPNCSU2006
If someone can post an answer on the board too, I'd appreciate it; I have the same codes in a friend's 96 ranger 4.0V6 5speed.
Old Feb 12, 2003 | 12:02 AM
Racerguy's Avatar
Racerguy
DTC P0125 INDICATES EXCESSIVE TIME TO ENTER CLOSED LOOP FUEL CONTROL
Diagnostic Trouble Code (DTC) P0125 indicates the ECT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting engine. This DTC will light the MIL.
Possible causes:
Insufficient warm up time.
Leaky or stuck open thermostat.
Low coolant.
Check coolant level.
DTC P1443: CHECK THE VOLTAGE ON THE PURGE FLOW (PF) SENSOR CIRCUIT VOLTAGE WITH ENGINE RUNNING
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor.
If I had to guess I'd say you probably need a new thermostat and a new Purge Flow Sensor.
LipRipper3006
Jan 3, 2017 07:31 AM
Semper Fordelis
15
Dec 6, 2015 06:22 PM
AKFord05
2004 - 2008 F150
Oct 3, 2015 02:37 PM
chardagha
Electrical Systems/Wiring
Oct 22, 2008 02:39 AM
TX76F250
Dec 17, 2005 12:53 AM
