Being curious, I went searching and it looks like it doesn't.
<DIR><DIR>• Pyro 1 (exhaust gas temp in F° or C°) • Pyro 2 (exhaust gas temp in F° or C°) • Speed (MPH or KPH) • Boost (PSI or KPA) • RPM
• Coolant (temp in F° or C°) • Throttle Position (0% to 100%) • Intake (temperature in F° or C°) • Barometer (PSI or KPA) • Battery (instant output in volts) • Fuel Pressure (PSI or KPA) • Load (0% to 100%) • Timing (in degrees) • MAF (mass air flow in grams/sec) • Fuel Economy (Miles/gal. or Liters/100 kilometers) • Fuel Flow (gallons/hour or Liters/hour)
</DIR></DIR>
<DIR><DIR>
</DIR></DIR>
Unless it has an expansion slot for an analog probe, it isn't going to be able to do that one as well for our vehicles.
What that listing is probably showing all the sensors that could be pulled from, but it would depend on specific model and/or year of the vehicle if it would be able to pull that for "your" vehicle.
