Morning sickness
Old Jul 23, 2010 | 04:17 PM
shocdoc's Avatar
shocdoc
Morning sickness
I'm asking if any here has had this problem and what is causing it. For the first ten minutes I drive my van , it winds in second gear while emmiting a whole lotta blue smoke . Once the engine has warmed to full operating temperature she runs fine with no smoke at all. She's running a little over 200,000 work miles with no major engine parts replaced except for the IDM computer. I got no trouble codes present. My second question is, for the last three fuel filter changes I have been finding a heavy wax buildup on the paper element , what can cause this?
Old Jul 23, 2010 | 08:00 PM
jwhitetail's Avatar
jwhitetail
Sounds like bad fuel as far as the wax goes, do you buy fuel at the same place all the time? You might have to drop the tank for a look see, and clean the crud, and replace screen etc.
Old Jul 23, 2010 | 08:17 PM
shocdoc's Avatar
shocdoc
This wax has been a problem ever since I started fueling in NY instead of PA. I have used several locations not to say that they might be supplied from one source. Tank was recoated a few years back and fitted with an external in line filter, not to say the possibility does not exist. could that be the cause of poor cold performance ? I've noticed this change over the last two months.
Old Jul 23, 2010 | 08:33 PM
jwhitetail's Avatar
jwhitetail
I know filter's are'nt cheap but change it one evening and than wait till morning and see how it runs, change the one from the tank also, run it than, take filter's out and see what they look like, if it is full of crud than drop tank and clean. You could also siphon some out and see what it looks like, also is the oil in good shape?
Montana Fordy
1983 - 2012 Ranger & B-Series
May 31, 2013 01:45 PM
busdriver47
Mar 13, 2013 11:29 AM
akamacgyver
Mar 6, 2011 11:58 PM
IceboxFX
Feb 10, 2008 11:23 AM
gumboluvr
Jul 31, 2006 10:19 AM
