Voltage Regulator?
Old Jul 23, 2010 | 08:46 AM
CABGx3's Avatar
CABGx3
Voltage Regulator?
Hi All......
My ride is a '89 Ford E150 Club Wagon, 5.0 EFI, AutoTrans. 61k miles. I have a larger Alternator because the Van was originally a Handicap Vehicle and had a second battery. My trouble is with the charging system. With RPM's up, the Ammeter shows a good charge but at idle with the front A/C on, it is barely above the Zero line and if I also turn on the rear A/C it drops below the line until I race the RPM's up.....then it will charge. Is this a sign of a bad Voltage Regulator..........should it not charge all the time, no matter the load? Is there an easy test I could perform?
Is there any kind of adjustment that can be made for this?
tks
Vaya con Dios,
Chuck, CABGx3
Old Jul 23, 2010 | 08:51 PM
maples01's Avatar
maples01
May have an isolator under the hood, they are designed to separate the battery's but charge them both by alternating the amps between the two, it may be bad, or removal of the equipment was done improperly.
Old Jul 23, 2010 | 09:10 PM
CABGx3's Avatar
CABGx3
Most interesting, I would have never thought of that..........I'll have my Mechanic check it out.
Thanks for your response
Vaya con Dios
Chuck, CABGx3
Old Jul 23, 2010 | 09:26 PM
maples01's Avatar
maples01
Welcome, mine has a relay, it just adds another battery to the factory one, disconnecting it when the key is off, the better way to do it in my opinion, doesn't require cutting into the factory charging circuit.
Old Jul 23, 2010 | 10:28 PM
rebocardo's Avatar
rebocardo
No, this is a normal sign of a high amp alternator. At low RPMs many put out less amps then a normal sized alternator. To prevent dips you usually have two batteries. You either have to change the pulley or up the idle slightly if it is a problem. The idle is suppose to automatically kick up at idle, but, it may not be kicking up enough RPMs for the larger alternator.
Old Jul 23, 2010 | 11:00 PM
maples01's Avatar
maples01
My high amp alternator doesn't do that.
