I had Ford change both my fuel filters in May. I ended up with a very slow drip coming from the water seperator . It wont totally shut off. Like I said its very slow, but its staining the driveway. Im going on a trip shortly,and if theres a fix I can try myself I'de give it a shot before trying to get it back to Ford. Any suggestions?
steve
Have you tried to open and close it a few times to see if you may have some trash in it that is not letting ot shut properly? I changed my filters last night and had some big flakes of trash come out of mine when I drained it. Just a thought.
year and model of your truck? screw in plug, or the lever? Under warranty or not?
under warranty, take it back... make en fix it..
sam
Forgot, though dont all 6.4 's have the same seperator setup? Its a 2008 350 . Theres a lever in the rail filter . I did try opening and closing to try and flush any particals that might be stuck there but its still dripping. The only other thing I could think of was trying a wiggling a wire around in there to loosen any contaminants.
I did get a Ford appointment for after the weekend. It was tough, my dealership has 1 diesel mechanic who's backed up, they were tring to book me next month.
Thanks
Steve
Ensure they actually clean the inside of the separator when the open it back up. You should always shine a flashlight in there if needed. They probably did not and there was something there.
