need help soon
Old Jul 22, 2010 | 09:57 PM
kdfishe43's Avatar
kdfishe43
Question need help soon
was driving the truck today and everything was running great when all of the sudden it just died and wont crank back. replaced cam shaft sensor or whatever it is, checked all fuses, checked fuel bowl and replaced filter, and still nothing. fuel bowl is filling and i can hear the pump running. ts is saturday so i'd really like some help on what else to look for. there was no rough running or anything it just died and now wont start
Old Jul 22, 2010 | 10:43 PM
bdrummonds's Avatar
bdrummonds
IPR gone bad possibly. Let it cool down and try to crank it again after a few hours. If it cranks it will only run about 10-13 minutes, until the oil temp gets up and the IPR is commanded to move. Best bet is to see if someone close has AE and can hook up and give you live readings of your ICP during the cranking. You need at least 550 PSI for the injectors to fire.
