1978 - 1996 Big Bronco
High Idol - PLEASE HELP!!!
Old Feb 11, 2003 | 07:10 PM
RyanGruhn's Avatar
RyanGruhn
Arrow High Idol - PLEASE HELP!!!
MY '83 Bronco is idoling around 2 1/2 grand even after 1 hour and 30 minutes of driving it. Is there somthing that is sticking that I do not know about? I try to kick it down by giving it some gas but it just stays at 2 1/2 grand. I cleaned the carb and all of its linkage so I dont think its the choke. Let me know what you guys think!
Ryan
Old Feb 11, 2003 | 07:12 PM
RyanGruhn's Avatar
RyanGruhn
I should add that YES it is cold out right around 20 if I am lucky, but I would think the truck would be warm after that much driving!
Ryan
Old Feb 11, 2003 | 07:38 PM
mrwizard's Avatar
mrwizard
It should never idle that high no matter how cold it is. Did this just start happening? Have you made sure the throttle linkage returns all the way to the idle position and isn't getting stuck on something. May sound silly, but make sure the gas pedal isn't stuck on a floor mat.
Old Feb 11, 2003 | 07:58 PM
steve83's Avatar
steve83
How long has it done this? If it only happened when it got cold out, I'd look at the fast idle cam & screw, and the thermal valve in the side of the air cleaner. If the hose isn't attached from it to the diverter on the neck, you could have a vacuum leak, but it shouldn't be THAT much. Listen around the engine compartment with a 3' piece of garden hose for a hiss - that's the vac leak that's allowing the engine to rev up so high.
Old Feb 11, 2003 | 08:31 PM
RyanGruhn's Avatar
RyanGruhn
It has been doing this for a while. I did get the engine rebuilt and I know that the hoses are not stock anymore for the vacuum. A couple people have told me that it might be that my choke is not opening or closing properly. I should add that it takes a good 25 pups of the gas pedal to get the truck started. This all started with in the last 3 months, so I have no idea if its just cause its cold, since I havent had it happen when its warm out yet. Let me know if the pupping leads you to believe it might be somthing else.
Thanks!
Ryan
Old Feb 11, 2003 | 08:52 PM
RyanGruhn's Avatar
RyanGruhn
if ya havent allready noticed my great spelling I meant "pumping" not "pupping"
Old Feb 12, 2003 | 03:49 PM
Kemicalburns's Avatar
Kemicalburns
so you rebuilt the motor, how about the carb. if your needing to pump the gas that much to get it started there is something seriously wrong. Have you tried adjusting the idle screw, checked your air/fuel screws. What kinda carb are you running??
Old Feb 12, 2003 | 04:52 PM
jeep8589's Avatar
jeep8589
You said this started happening when you rebuilt the engine. I am not trying to insult your intelligence but have you tried adjusting the throttle adjustment screw. Reason I ask this is that for the first 20 minutes of running on a new cam you should idle about 2200 rpms to break in the cam. THe idle may have been intentionally turned up that high to break in the cam. The second thing I would look for is a stuck or bad float adjustment. When a carb usually goes bad, the idle drops off due to vacuum leaks around the throttle shaft etc. causing a lean condition. It appears to be getting extra fuel instead of less. If the float isn't operating properly you may be spilling gas into the carb through the bowl vent tube. You shuold be able to see this easily from looking down the top of the carb. This would cause a rich condition and you should see carbon coming out of the tailpipe. If you are not seeing this then something is holding your throttle plates open allowing it to get extra fuel and gas, so double check all of your linkages. I would make sure that the throttle shaft isn't bent keeping it from closing completely.
Old Feb 12, 2003 | 07:33 PM
RyanGruhn's Avatar
RyanGruhn
I have a motocraft carb (2 barrel). Where are these screws? (Idol, feul/air) do you guys have any on-line pictures of where they are on the carb? When I try to kick the idol down manually under the hood it wont go down either. Yet when I gave some slack to the throttle into the carb it backs off. Sorry I am not all that technical. could somthing be sticking somwhere? Is it safe to use some good ol' WD-40 on all the springs and moving parts around the carb (throttle linkage)??
Ryan
Old Feb 13, 2003 | 09:07 AM
Kemicalburns
from what your saying it sounds like the linkage is getting bound up some how. with out looking at it hard to say whats causing this. You might try the wd40, you might also think about just yanking that 2barrel and manifold and look for a good edelbrock intake. You would a lot happier and so would the motor. Now off hand i cant picture your throttle linkage is it a cable or a bunch of levers and springs. mine is efi so taking a pic wouldnt help you at all. sorry.
the air/fuel screws are on the bottom front of the carb. these are one screw for each side with a small spring wrapped around each on. I believe the correct adjustment to start with is to turn them all the way in clockwise, then back them back out either 1.5 turns or 2. then start the truck and continue turning out till you get desired idle and the exhaust isnt smoking. I would get a haynes/chiltons manuel it will explain this and be a big help down the road for other situations.
good luck
Old Feb 13, 2003 | 01:53 PM
JBronco's Avatar
JBronco
Maybe it's a false idol?
Old Feb 13, 2003 | 05:21 PM
steve83's Avatar
steve83
J
Ryan
You might find pics of the carb here.
