F1 vs F3
They are different. The F-1 transmission is a lighter duty, synchronized, the F-3 will be a non-synchronized "crash box" transmission. The usual maneuver is to change from the crash box to a synchronized transmission. If you like double clutching through all the gears, and double clutching to down shift, I doubt you're going to like the swap especially having to the modification to make it fit.
You'd do best if you want a stock floor shift to use a pre-mid '50 floor 3 speed out of another F-1. F-1 came with light duty and heavy duty 3 speeds.
You might want to check into switching to a T-5 transmission. Do a search of this board on "t-5", you'll find a lot of information.
F1 vs F3 transmission
Thanks for the info. I have been looking for a floor shift F1 transmission for months without any luck to this point. I have a column shift but my son wants a floor shift and while the body is off the frame and the engine is rebuilt I would like to get this done. Does anyone know of a F1 floor shift transmission out there. I have found on person that has the case but does not have the top shift part. If someone has the top shift part please let me know. Thanks
Ma Van Pelt will should be able to help you with information on your parts search and maybe a whole transmission. Ford Transmission Parts Prices
Hi All.
In answer to Brian1950. Yes I am definitely interested and still looking. I need a transmission for an F1 with a floor shift. 1949 would be fine. Let me know
In answer to Jmadsen. I spoke with your friend at the beginning of the week and he has the case but does not have the top part with the shifter. He said he would try to located one. I am to call him back in a few weeks.
sancochojoe
04-16-2005 07:54 AM
revinbluejeans
09-02-2003 10:48 AM
