In Baja with rear wheel squeak, brake problem?
Have you considered what those gas vapors do to the rims, valves, and tires?
I'm sure the petroleum vapors are less harmful than whatever the chemicals are that is in the FOF.
The can of F0F is to get you to the next town. Once there the tire can be taken apart, repaired, and wiped clean.
Quote:
Originally Posted by Moto Mel
have a source for air, such as a spark plug fitted with a long flexible air hose and use the engine as an air compressor.
Huh? I've never heard that one.
Touring motorcyclists have been doing that for decades.
Fix O Flat will make you wildly unpopular with your tire guy. It doesn't just wipe off, it is a nasty gooey mess that coats the tire and rim.
I am with alloro on the spark plug thing. No way I am pulling a plug on a 5.4 to fill a tire.
I just carry and air compressor that I connect to the battery and a good supply of tire plugs. This is a way more versitile set up than the others mentioned.
If it's a 4wd with the 2 piece rear drive shaft, check the middle joint. When I had my '97 it started squealing while I was on vacation in FL 1300 miles from home - it made it home just fine. Unfortunately the fix was to replace it with the newer design 1 piece drive shaft $$$ (but that was a long while ago).
It's very hard to give any accurate pointers in your situation. I would first check the springs that you replaced and if it is that, again. you will have to find the cause. Maybe if you post a video with the sound it will strike a chord with someone here.
Whistlepig Hollow
02-26-2014 01:36 PM
