Sponsored by: Auxito
Electrical problems
Old Jul 22, 2010 | 11:17 AM
kirkzee214's Avatar
kirkzee214
Electrical problems
I have a 2006 ford ranger. a few weeks back the abs light came on then the emerg brake lite then the air bag light. then it started running rough, when i turned off the ac it started running fine . then i turned on the lights --running rough again. it finally killed at a red light. i brought the battery in and tested fine just need charging. put the battery in and every thing was fine . a few hours later it started the same process again. I pulled the alternator and brought it to a rebulid shop and they said it was fine they tested the battery and said IT was bad. I changed the battery and it was fine for a few weeks. yesterday it started acting up again after i turned it of it would not start. this morning it starts right up. I ran it a little while shut it off and it started right up again???????
Old Jul 22, 2010 | 12:41 PM
Navyguns's Avatar
Navyguns
Sounds like your alternator is dying a slow death. Get a new alterator and fully charge the battery before running with the new alt.
Old Jul 22, 2010 | 02:50 PM
1Aauto's Avatar
1Aauto
Former Vendor
Did you check the ends of the battery cables to see if they are corroded? If you haven't yet I'd clean up the cable ends too.
tyman00
1997 - 2003 F150
Feb 19, 2014 11:21 PM
charlene3369
15
Dec 11, 2012 01:22 PM
kirkzee214
1983 - 2012 Ranger & B-Series
Jul 24, 2010 09:49 AM
Barty88
Oct 6, 2009 08:57 PM
T-rav
Sep 6, 2009 04:52 PM
