Determing which axle I have...
Old Jul 21, 2010 | 07:51 PM
fjatheart's Avatar
fjatheart
Where on my '94 F-250 Supercab, 4wd, longbed,
460 can I figure out which axles were put under my truck?
That's a mouth full! Thanks
Old Jul 21, 2010 | 07:55 PM
96ford250's Avatar
96ford250
well with out any pics most likely d50 up front sterling 10.25 in back
Old Jul 21, 2010 | 08:14 PM
crazy4wdracer's Avatar
crazy4wdracer
You have a Ford/Sterling 10.25 in the back. I'm not sure up front because I'm not too familiar with 4WD's buy I would guess Dana 50 or 60.
Old Jul 21, 2010 | 08:16 PM
96ford250's Avatar
96ford250
unless a converson was done its a d50 only f350s came with the d60 but its not uncommon to do the swap so we need pics
Old Jul 21, 2010 | 08:35 PM
LCAM-01XA's Avatar
LCAM-01XA
From the factory it was a D50 front, and a Sterling 10.25 full-floater rear (there is also a semi-float Sterling, but it's was used on the light-duty F250s, which yours clearly ain't).
Old Jul 21, 2010 | 10:46 PM
fjatheart's Avatar
fjatheart
tappered add a leaf?
Since we know what kind of axles I have. What are your thoughts on leveling the truck with an add a leaf up front and adding 5100 Bilstein's?
Does anyone know if the add a leaf springs have to be tapered? Read on another forum non tapered would not work.
Thanks!
