timing question
Old Jul 21, 2010 | 02:57 PM
jd4300's Avatar
jd4300
timing question
question on my timing on my 86 5.0 FI engine with AOD tranny
at an idle with everything plugged in what is normal timing. I can set it to 10 degrees with the spout connector disconnected. at idlel with everything connected i am around 3 t o 5 bdc.
my truck runs great as along as i am accelerating if i idle or cruising at 5 to10 mph it hesitates and surges.
any help is appreciated
Mike
Old Jul 21, 2010 | 03:37 PM
Orcburner's Avatar
Orcburner
[quote=jd4300;9133983]question on my timing on my 86 5.0 FI engine with AOD tranny
I have the exact same truck . unplug the EEC connector by the distributor. Set the timing to 10 degrees btc. reconnect the EEC.
mine also surged like that. i'm not sure what exactly fixed it because i replaced all my sensors and upgraded to msd distributor and coil at 150k miles.
Old Jul 21, 2010 | 04:46 PM
Franklin2's Avatar
Franklin2
Always check for codes on these fuel injected trucks. You can waste a lot of money by guessing.
truckmonger1
Engine Swaps
Jul 20, 2012 08:05 AM
93f15042
Dec 2, 2010 08:29 PM
janvan.1
2004 - 2008 F150
Apr 25, 2010 05:32 PM
DKdude
Dec 18, 2007 05:21 PM
thebbp
1978 - 1996 Big Bronco
Jul 1, 2001 01:47 AM
