Moving from Washington state back to Nebraska guys gonna be pulling a loaded 5th wheel and would like to get a check list of things to check or change on the truck. I have a 96 F250 ex cab 4:10's, no kitty, 3 down 4 exhaust, 6637, gauges, upgraded turbine, turbo housing changed from 1.25 to 1.0 from, newer glow plugs, rebuilt tranny with tranny cooler, allot of these were done before I got it. I am changing all fluids replace shocks and brakes. Also replacing tie rod ends and dif fluids. The kids and I are making this journey so I want to make it as safe as possible, any and all help would be much appreciated.
Thanks
Jim
An extra serpentine belt is handy to have. Extra motor oil, a flat repair kit (plugs), some bottled water in case you do get stuck for a bit, and a set of warning triangles and a couple of flares in case you need to keep oncoming traffic away.
Does the trailer have brakes? Check them. What about the emergency disconnect battery? Still good? How old are the tires? Almost all the trailer tires I've had blow outs on still had lots of tread on them, they were just old.
Thanks for the info and well wishes. Yes good trailer brakes, bat, all lights work, good wipers, good grease, changing front and rear end fluids, two new tires on the trailer other two are a year old. Would going back to the 1.25 be better? For some reason the p/o thought the 1.0 would spool faster which he thought that would be better.
Is there anyone on here from the Omaha area as I am learning allot on here but hands on for me is thee best way thought maybe I could buy some beer and pizza and we could talk some truck.
The1.0 will spool faster but cause higher egts. The stock 1.15 is better for towing, if you don't do too much towing the 1.0 should be ok, I'd get an egt gauge though.
[quote=Jim Hunt;9136191] Would going back to the 1.25 be better? For some reason the p/o thought the 1.0 would spool faster which he thought that would be better.
[quote]
The 1.0 spools faster, but will give you higher EGT's as well. Especially if you are towing the 1.15 is better. (We have a 1.15 stock, not 1.25)
would the fpr shim help me at all looking for a bit more towing power and more mpgs but so not want to burn my truck up. We are going to be headed across the country with a 96 250 pulling a loaded 27' 5er and a 94 rangers pulling a 90 ranger pick up trailer this ought to be comical at the least
