AC Belt vibration on 1977 F250
Old 07-20-2010, 09:19 PM
oldjag's Avatar
oldjag
oldjag is offline
I have the factory AC on my '77 F250 460 Supercab w/Auto trans. Just off idle, the belt "dances" between the compressor pulley and the crank pulley when the compresser is running. This makes a very annoying noise and vibration. I've tried tightening the belt and tighter seems a little better but I'm afraid of damaging the compressor or water pump bearings from excessive tension. Otherwise the AC works fine. Anyone else have this issue? The twin cylinder York compressor on my '64 Ford Galaxie never had this problem, I recall it had a much more massive flywheel on the compressor.
Old 07-20-2010, 09:38 PM
02X72's Avatar
02X72
02X72 is offline
Make sure that the pulleys are lined up properly using a yard stick, thats where I would start. If they are, I would be inclined to think that something is wrong mechanically with the A/C compressor that is causing it to act like that way. Dont know if you might have replaced belts recently either, but make sure that it is the right size, mainly width if you did. Just a start...
Old 07-20-2010, 11:15 PM
oldjag's Avatar
oldjag
oldjag is offline
The belt alignment is fine and the belt is new. The vibration only happens in the 900-1200 rpm range, above and below that it's acceptable. Seems like a standing wave gets set up on the belt from the compressor torque pulses. Maybe this is somewhat inherent with compressor with only two pistons. Probably partly why the newer designs are rotary or have more pistons. The high and low pressures are normal.
Old 07-21-2010, 08:01 PM
fair67driver's Avatar
fair67driver
fair67driver is offline
I had the same problem with my 79 351m. Double check your refrigerant charge. If it is overcharged any at all, it will pulse more. I recharged mine and it is much better now.
Old 07-22-2010, 06:47 PM
jsutton's Avatar
jsutton
jsutton is offline
Mine moves around and makes a vibrations at around 550 rpm's, like when the A/C is on and it's in gear idling at a red light. I've gotten to where I just flick it to vent when at a redlight and then back to A/C when I take off. Cause I haven't gotten around to installing the idle control solenoid to bump up the idle when the A/C is on.
Old 07-22-2010, 07:43 PM
redsuperduty's Avatar
redsuperduty
redsuperduty is offline
Mines the same as jsutton. I think I need to adjust my idle solenoid.
marcogyver
1997-2006 Expedition & Navigator
09-10-2016 08:33 PM
Rusty_S
04-05-2015 01:43 PM
jarod17
09-24-2008 10:47 AM
SirTweakAlot
12-19-2007 09:06 AM
mtandorfer
08-01-2004 03:18 PM
Quick Reply: AC Belt vibration on 1977 F250
