Door locks Relay//door ajar light
Old Jul 20, 2010 | 03:43 PM
mjtpolice76's Avatar
mjtpolice76
My door locks stopped working, door ajar light in the dash stays on and the radio does not shut off when the door is opened upon exiting the vehicle. Checked the owners manual for a fuse or relay. The owners manual says fuse 102. I checked that seem good even switched it with anthor fuse still didn' t work. I'm at a loss and I dont want to go to the dealer. Is there a switch in the door or relay in the door that I should be looking for? Mike
Old Jul 20, 2010 | 07:33 PM
nissandoc's Avatar
nissandoc
Dont know what year truck you have but read this: https://www.ford-trucks.com/forums/9...-turn-off.html
Old Jul 20, 2010 | 07:57 PM
mjtpolice76
Sounds like the VSM its an 2002
Old Jul 20, 2010 | 07:59 PM
nissandoc's Avatar
nissandoc
Pull fuse #19 for about 10 seconds then put it back in.
It works for me when mine does this.
Old Jul 20, 2010 | 08:33 PM
mjtpolice76
I assume that I pull fuse when it's running?
Old Jul 20, 2010 | 09:17 PM
pjnadon's Avatar
pjnadon
Mine does that when i try to start the truck when the battery is drained down. I just disconect my battries the VSM resets itself
Old Jul 20, 2010 | 09:28 PM
nissandoc's Avatar
nissandoc
I do mine with engine off, key out of the ignition.
Old Jul 20, 2010 | 09:55 PM
mjtpolice76
Tried to disconnect batteries didn't work tried pulling fuse didn't work
Old Jul 20, 2010 | 10:08 PM
pjnadon's Avatar
pjnadon
I would say your VSM is shot here is a link when I was having the problem https://www.ford-trucks.com/forums/9...t-come-on.html
Old Jul 20, 2010 | 10:14 PM
pjnadon's Avatar
pjnadon
There is also switches in where your door latches are try spraying them with WD 40
