rearview mirror
Old Jul 20, 2010 | 10:26 AM
wipper's Avatar
wipper
rearview mirror
my inside mirror leaked so i need to replace it i just can't see how to take the old one off .
i have unpluged it
it is the mirror that auto darkens this is in a 2001 limited.
Old Jul 20, 2010 | 11:14 AM
BAJI26's Avatar
BAJI26
Mine too have been bad for a while, where and how much can I get one for?
Old Jul 20, 2010 | 11:33 AM
mark996's Avatar
mark996
Is the metal button still glued to the windshield? There should be a set screw or something on the bottom of the metal button that the mirror slides on to, after that, I always took a small thin item, like a razor blade and worked it off that way. Some have a channel that you can work a small screw driving in to, working against the button and the glue to get it off. After that, clean it real good with goo off or some other type of cleaner, both the windshield and metal button the mirror slides on to. Before you start, take a crayon or something similar and mark on the outside of the windshield where your mirror is, that way you get it back in the same place when you go to reinstall it.
Old Jul 20, 2010 | 12:29 PM
UrbanXX's Avatar
UrbanXX
I can usually get these around the local junk yards for around 25.00 each. If they are the same as on an 03 Excursion. Mine has a little green light that shows its on. If I can help I will. I'm going to look for a few odds and ends this week-end if it dosen't rain. I need some of the door handel plugs and of course am always looking for V-10 spare parts just in case I need them. The V-10 parts are hard to find around here.
Old Jul 20, 2010 | 01:05 PM
howler4x4's Avatar
howler4x4
What does the push button do and little green light mean?
Maybe it's because my rear glass is tinted, but I've never seen any difference in the mirror, little green light on or off.
Old Jul 20, 2010 | 02:16 PM
wallz's Avatar
wallz
i have unpluged it
If you look at the bottom of the base that is on the glass you will see a small hole/slot there. Use a small flat screwdriver or awl and push it up in there from the bottom, as u pull up on the mirror. Little spring clip holds it on to the base that is glued to the glass. You new replacement will just slide on from the top, and you will want to just snug it into place. If you ever pull of the base don't even bother wasting your time or money buying the do it yourself kits. I end up having to clean all that cr@p off and doing it right, and have never seen one come back. Go to a glass shop and they can glue it on properly if it ever happens.
Use car-parts.com or burco.com to order, find replacement mirrors.
nerksa
24
Sep 9, 2013 03:41 PM
firepop5
Mar 22, 2012 09:33 AM
kyle.good
2004 - 2008 F150
Feb 9, 2012 06:27 AM
remix01
Feb 19, 2010 01:26 PM
