This has happened about 3 times over the past month. When I turn the ignition switch I hear a click under the hood but the starter doesn't turn. If I keep turning the key or wait a couple minutes and try again it starts right up. Is this the starter going bad? or something else? Please help as I want to fix it before I get stranded somewhere.
Just happened to me two weeks ago. Replaced the solenoind by the battery and no porblems since. It was about $20 at Napa and less than 5 min. to replace.
Before replacing the solenoid, make sure the connections to it are clean and tight, making good contact. Mine were lose and that was all it took to clear the problem up. I thought I was stranded too, until I noticed the arcing on the solenoid at the negative side. Tightend it up, and fired right up.
I usually find my problem at the negitive side of the solenoid, too. Although, a couple weeks ago I found I had a wore out alt. It wasn't all the way dead, but enough that when I turned on my lights the guage would dip to neg a little. One of these days I'm going to replace the harness around the solenoid and get rid of the hatchet job somebody did on it.
If you are hearing the solenoid under the hood click over your problem may still not be the starter itself. On your starter there should be a secondary relay down on the starter. Steve83 pointed this one out to me. There is a 1/4" spade terminal connection on my 92 that runs to the secondary relay on the starter. Mine did the same thing just the other day. I replaced the original bare spade terminal with a fully insulated female spade to keep the salt and grime off of it. Turned out that terminal was just filthy and was keeping the other relay from engaging. Cleaned the male spade term. and replaced the female one. Works like a charm.
